94 s10 power window
Old Jul 8, 2011 | 01:44 PM
tony42's Avatar
tony42 is on a distinguished road
Default 94 s10 power window
passenger side window does not move. I don't know if i need to replace the motor or what is wrong with it. any suggestions?
Old Jul 8, 2011 | 01:46 PM
xgiovannix12's Avatar
do you hear the motor trying to move? mine gos up and down slowly its starting to bug me . my motors burning out i think
check if you got power at the motor with a test light
Old Jul 10, 2011 | 08:21 AM
tony42's Avatar
Default motor
no noise it just sits there. That's why I'm hoping that it's just not getting power. Also I'm new to electric work, so how exactly do I test the power with a test light?
Old Jul 10, 2011 | 10:40 AM
ground the clip to the body of the truck .
put the point into the plug that's on the motor also make sure the test light is Grounded correctly . I suggest grounding it to the battery if the wire is long enough
Old Jul 10, 2011 | 11:53 AM
tony42's Avatar
Thanks for the tip. Everything checks out fine. The fuse is good and pressing both up and down on the switch lights up the tester. So, power is getting to the motor, but nothing happens. Where should I go from here? thanks again for all your help.
Old Jul 10, 2011 | 11:54 AM
your motor went KAPOOT or i can say get a casket for it ?
Old Jul 15, 2011 | 09:35 PM
tony42's Avatar
ok... that's what i thought...however, i've been told that they are spring loaded and everyone that Ive talked to has had their hand lacerated when trying to remove them....what is the best way (aside from leaving it be) to avoid this?
Old Jul 15, 2011 | 10:11 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Geez - what were they doing? I've done 2 without any problems at all. Unlike the guys in the link below, I use a c-clamp through the arm to the regulator body. It works great.
Diagnosing and replacing a power window motor
knitter0217
Mar 17, 2012 08:00 AM
Chasen D
Jan 21, 2012 09:51 AM
bigslik20
Aug 9, 2011 11:32 AM
GHN111
Oct 3, 2009 07:52 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
