95 Blazer Wiper stops low speed - any fix?
Old Apr 3, 2019 | 01:57 PM
ardenlester00's Avatar
ardenlester00 is on a distinguished road
Default 95 Blazer Wiper stops low speed - any fix?
Hello,
My 95 Blazer windshield motor lost its low speed. Is there a simple fix? (I can't afford a new wiper motor system)
Looking forward to a simple fix!!
Thanks,
Dennis
Old Apr 3, 2019 | 02:48 PM
cleburne red's Avatar
Not sure if it'll help you, but maybe take the wiper control board apart, and check the contacts. Mine was acting up, not turning off, etc, and I found a couple of contacts were bent, and not making good contact. Just bent them back with my hand.
Also, do a search for, I think, "wiper motor cold solder" something along those lines. Seems to be a fairly common problem on these trucks
Old Apr 15, 2019 | 10:33 AM
troynic66's Avatar
troynic66 is on a distinguished road
mine did the same and would stop working I took out the what ya call it.. mother board for the wiper motor and re soldered all the contact points .. did the job.. cheap fix
Old Apr 16, 2019 | 06:10 AM
Thanks friends for your good advise. I got the courage to take it apart - took the circuit board out and found blown condenser - and burned all over.
It was quite simple to do - and now it works perfectly. Cost of the circuit board through Amazon - less than $15.00. Dennis
Old Apr 16, 2019 | 08:47 AM
Nice! Glad you got it fixed up!
george154302
Oct 22, 2011 10:16 PM
renee48742
Oct 17, 2009 04:45 PM
yzf125
Nov 10, 2005 06:12 PM
tdannar
Aug 24, 2005 08:11 PM
