97 s10 Blazer no running lights, 4/4 dash control is inop, please help
Old Mar 12, 2020 | 10:18 AM
Rhino123's Avatar
Rhino123 is on a distinguished road
Default 97 s10 Blazer no running lights, 4/4 dash control is inop, please help
my 97 Chevy Blazer 4 x 4 4.6 l LT. don't use the vehicle as much anymore. Recently took it to local shop for heater core. But, after heater core repair the car sat for the better part of winter. In recent months done some work to the vehicle but nothing to do with electrical outside of changing my turn signal assembly the brake switch and the light switch. I changed the brake light switch because the third lamp was working but my tail lamps weren't. My hazards were a little bit touch and go so... I changed that assembly. pretty much plug and play. I have been chasing a GREMLIN for the running lights. I still cant figure out why my running lights my license plate light and my four wheel drive and my instrument cluster light s will no longer operate I have checked for bad fuses. Please help!
Old Nov 12, 2020 | 01:15 PM
96blazerguy1's Avatar
96blazerguy1 is on a distinguished road
Default Same issue with my 96
I'm having the same problem did you ever get it figured out?
Old Nov 12, 2020 | 11:56 PM
that1guy's Avatar
that1guy is on a distinguished road
Check your fuses. I had the same issue and I blew a fuse when I replaced the underhood light bulb without disconnecting the battery.
l0st s0ul
Dec 12, 2015 03:13 PM
da_jester
Oct 27, 2012 05:53 AM
rafa.jrbarajas
17
Jul 3, 2009 12:46 PM
SittinHigh
Nov 30, 2008 03:01 PM
joe
Jun 11, 2007 06:46 AM
