'99 Jimmy fuel pump won't turn on with 12 volts.
Old May 5, 2019 | 04:07 PM
Rylesf's Avatar
Rylesf is on a distinguished road
Default '99 Jimmy fuel pump won't turn on with 12 volts.
The car turns over but won't catch, I've tested a couple things now and am now looking at the fuel pump. Putting direct power off the 12 volt battery won't activate the fuel pump, but using a 9 volt battery will turn the pump on. Is it just a bad fuel pump? Or something else?
Old May 5, 2019 | 04:53 PM
cleburne red's Avatar
How are you applying 12v to it? Checked grounds?
Old May 7, 2019 | 02:26 AM
Rylesf's Avatar
Turns out there was a bad fuse in the wires I was using, totally overlooked it. Thanks anyway
Old May 7, 2019 | 05:02 AM
Glad you got it figured out!
Fat Snook
28
Apr 18, 2016 08:50 PM
ohiofossil
May 5, 2015 09:33 PM
fixer34
Mar 16, 2014 10:45 AM
masterrcs971
Feb 22, 2010 07:04 PM
i3lomeh
Mar 21, 2009 09:00 AM
