absence of trouble codes
Old May 28, 2018 | 04:40 AM
StarScreamin's Avatar
StarScreamin is on a distinguished road
Default absence of trouble codes
Greetings; I'm going to try my best to describe wut is going on with my '99 s10 blazer 4x4 ( so please bare with me).
since I got the rig , there has been several times in which it has had a problem or issue, ( misfire, broken speed sensor, not running good at all going up hill , etc. So while trying to get things fixed, I plug in my OBD2 code reader in, & guess what!: no stored codes, no recent codes, nothing.
not only has ther never been any trouble codes, the S.E.S. light has nvr came on to notify me of a problem. & the S.E.S. light does work, it lights up when I turn the key to start the engine.
I don't know if it matters, but, when I was driving my '98 s10 blazer 4x4, that S.E.S. light would light up when there was issues with emissions, transmission trouble, etc.
so my question is this: why isn't my S.E.S. light lighting up to inform me of a problem?
Old May 29, 2018 | 08:32 AM
LesMyer's Avatar
Does the SES light work with the key on/engine off?
Old May 29, 2018 | 11:22 AM
Yes, after turning the ignition to on ( not to start) it stays on until after I start the rig
Old May 29, 2018 | 01:25 PM
LesMyer's Avatar
Then it is working. Certain conditions have to be met in order for a specific code to set, but usually failure to come on is never a problem! Especially with a misfire. If you have concerns regarding failure to set specific codes you can review the documentation in the OBD2 codes portion of the Tech Section to find out what triggers the particular code to set and turn on the SES light. Hope that helps.
Old Jun 1, 2018 | 05:14 PM
Default enhanced trouble codes
So after being able to access the enhanced GM codes in this '99 s10 blazer 4x4, it came up with 5 codes:
P0605:control module programming
U1026: loss of class 2 communication with ATC
U1042: Lost communications with brake/ traction control system
U1192: loss of passlock/ EVO class 2 communication
U1193loss of VIM class 2 communications.
Now, could someone please explain what these mean?
thank you ahead of time for all your help.
Old Feb 16, 2019 | 06:56 PM
my old blazer's Avatar
my old blazer is on a distinguished road
Default Codes list
There is list of codes at this site. All of those communication codes should clear if you fix the P code. Sounds like you have a bad communications module. Maybe the computer needs to be reflashed??
thog472
Aug 14, 2020 06:51 PM
Asuryan9
Jan 5, 2013 05:58 PM
navynuke09
Apr 9, 2010 12:03 AM
stevette
Mar 26, 2009 07:59 AM
blazinloud
Engine & Internal
May 1, 2006 02:53 AM
