AC clutch always on
Old Mar 17, 2020 | 05:35 PM
Garage Guy's Avatar
Garage Guy is on a distinguished road
Default AC clutch always on
AC relay always has power on 85 and 86. This is with key on. Compressor runs constantly. I’ve removed relay so my son can drive(his truck). I’ve pinned out to ecm with good continuity, both low and high plugs. Also pinned clutch control. Chased back to relay center under hood. Pin 85 and 86 both have 12v. Help please
Old Mar 17, 2020 | 08:13 PM
If 85 and 86 both have power, the relay shouldn't be energized. One of those (85?) needs to be grounded. Is it possible that 30 and 87 are shorted internally in the relay?
Old Mar 17, 2020 | 08:26 PM
Garage Guy's Avatar
swapped multiple relays. No change. Probed the relay block under hood with relay out and verified 12v on both with key on. Separated wires from ECM all way across to relay block. No shorts, burns, anything. Does BCM control ac clutch?
Old Mar 17, 2020 | 08:28 PM
Give me the vitals on your Blazer and I'll find a wiring diagram.
Old Mar 17, 2020 | 08:39 PM
Garage Guy's Avatar
1999 4dr 4x4, LS. Standard options nothing fancy.
Old Mar 17, 2020 | 08:49 PM
Here you go.
File Type: pdf
Old Mar 17, 2020 | 09:01 PM
Garage Guy's Avatar
Here you go.
thank you. This shows what I’ve seen one leg hot all time, second leg hot on key. Guess I’ll keep chasing it. Something isn’t commanding clutch to unlock.
Old Mar 17, 2020 | 09:03 PM
The PCM should ground one side to engage the clutch.
Old Mar 17, 2020 | 09:14 PM
Garage Guy's Avatar
That points to an internal PCM failure. I’ve already verified continuity from pins to ground at PCM plug on all blk/wht. Oh well thanks for the help
Old Mar 17, 2020 | 09:34 PM
Sorry I don't have a better answer for you. Good luck.
okaussie
Mar 14, 2020 02:36 PM
ferret13sj
Jul 10, 2018 11:10 AM
jimmy_for_ever
May 5, 2018 08:09 AM
schmuve
May 25, 2010 10:30 PM
red blazer
Aug 16, 2009 06:09 PM
