Air bag light
Old Nov 23, 2010 | 07:40 PM
gmbwrenchn's Avatar
gmbwrenchn is an unknown quantity at this point
Default Air bag light
Just recently I'm driving along and I had the air bag light go on briefly. At the same time there was a beep inside the dash AND it felt like the car was going to stall. This happened to my daughter while she was driving it, only it did stall.... complete shut down while driving, but started right back up again. Thanks for the help.
Old Nov 23, 2010 | 07:47 PM
Could be the initial signs of an ignition switch failure. You could have the airbag codes read to see if anything was stored.
Old Nov 23, 2010 | 09:21 PM
gmbwrenchn's Avatar
Does that require a sophisticated reader like at a dealer? Thanks.
Old Nov 24, 2010 | 02:17 PM
It does require an enhanced (full feature) scan tool, but the dealer isn't your only option.
Old Nov 24, 2010 | 03:42 PM
Benedict1337's Avatar
mine has been going off and on too, i probably won't bother getting it fixed
Old Nov 24, 2010 | 03:49 PM
gmbwrenchn's Avatar
Looks like I have someone lined up. Friend of mechanic. Will scan it for free. Will charge $70 to diagnose the problem. I'll report back with the codes, thanks.
Old Nov 28, 2010 | 11:35 AM
gmbwrenchn's Avatar
Well I never made it to get the Air bag code read. Blazer died and won't start at all.Turns over....sounds like it wants to start, but won't. Had to have it towed. Everything shut off while I was driving along. Good thing I was only driving 35 mph! Well..........I need a educated guess on this problem, cause it's at my house and I plan on fixing this myself. Would you say that it's most likely the ignition switch? I know there is no way knowing that's it 100% but I just want odds. Thanks for the advice.
Old Nov 28, 2010 | 02:17 PM
You may be experiencing an ignition switch failure. That could link all of the issues you are experiencing together.
You could check all of the grounds and splice packs under the dash to be certain that it isn't just a grounding problem as a next step before replacing the ignition switch.
Old Nov 28, 2010 | 04:36 PM
gmbwrenchn's Avatar
Thanks will do, then post back.
Old Dec 13, 2010 | 09:18 PM
gmbwrenchn's Avatar
Well I checked everything the best I could under the dash. Everything looks ok. I want to go in and replace the ignition switch. 97's had problems with the ignition switch anyways I believe. Any step by step posted proceedures on doing this successfully? Thanks.
