All power goes out when trying to turn on
I have a 97 Blazer 4 door 4x4. When I try to turn the truck on all the power goes out. Everything! Sometimes if I just open and slam my door shut the power turns back on. Sometimes I have to wiggle the battery. Usually after a couple times of this it starts. Any suggestions would be greatly appreciated. Thanks
Thanks. I will check all those when I get home from work. I have checked to make sure the cables are tight on the battery but will check again. And to make sure, I can find the ground wire coming from the negative on the battery right?
I checked the cables. I guess the negative could of been a little loose. I don't really know how to tell though. I also don't know where the ground is. The truck started right up today. This problem only happens sometimes
Thank you. If the problem happens again after I tighten it I will be posting again. It doesnt happen every time I start the truck. So it might be a while to find out. I try not to drive too much
