All speakers out.
Old May 26, 2013 | 06:33 PM
spittybays
Guest
Posts: n/a
Default All speakers out.
Lived with the old delco am/FM cassette. Speakers would go on and off, mostly on then mostly off then all off. After listening to myself for about a year put a brand new Kenwood in today.
Worked on pre-button up test. Sound from four speakers. I do not believe there is a external amp. 12v to black ground on both switched and un-switched. Resistance on all speakers from connectors shows open.
Anyone know if the harness from the back of the radio goes to another harness behind the dash were the wirer's divide.
Any ideas how to trouble shoot this problem.
I know less then zero on car audio.
Even something on the most basic would be a great help.
Thank's....Jeff.
Old May 26, 2013 | 06:40 PM
rexazz2's Avatar
I would guess thing in common between all speakers is the ground
Old May 26, 2013 | 06:59 PM
rexazz2's Avatar
I couldnt find a wiring diagram for the 95 but the 96 looks like all radio grounds go back to the rear of the motor
Old May 26, 2013 | 07:51 PM
spittybays
Guest
Posts: n/a
I was looking at that but the speakers have two wires each a pos and a neg that come of the radio and that ground is good. With the speaker wirers reading open that makes me thing some kind of routing block thats undone. It dosent show one on the schem, so maybe there is an amp somplace but its the base system I think?
Old May 26, 2013 | 08:02 PM
richphotos's Avatar
If there was an amp, it would be in the center console. There is no routing block otherwise, the wires come off the head unit directly to the speakers
Old May 26, 2013 | 08:29 PM
rexazz2's Avatar
I am stuck on a ground issue
try a jumper cable from the engine block to the body
any mods in , console ,fender, rocker area or tail light wiring around the time this started happening ?
I have seen screws threw the carpet that caused the entire interior to be removed to track down
Old May 26, 2013 | 08:45 PM
spittybays
Guest
Posts: n/a
The investigation will continue, thanks guys.
Old May 31, 2013 | 10:04 PM
spittybays
Guest
Posts: n/a
Fixed! Four new speakers from Amazon. All speakers showed infinite resistance at the HU.
I just don't know how I will know what the next thing to replace will be till it falls off now that I have music.
altoncustomtech
Mar 27, 2014 06:00 AM
kevinph
Mar 29, 2013 03:51 PM
whitezr2
Nov 7, 2010 09:26 AM
tjwiens91@hotmail.co
Jul 20, 2010 01:29 AM
batmangoalie77
Feb 26, 2009 01:11 PM
