Alternator confusion
Old Aug 16, 2011 | 10:49 AM
appliancguy's Avatar
appliancguy is on a distinguished road
Default Alternator confusion
Yes I searched before posting, left to more confused. My 99 blazer has a 1 wire alternator, nothing fancy right? Puts out 14 volts cold but 12.8 - 13.2 hot and when i hit the power window with the a/c running the gauge drops. I've updated all the battery cables. I thinking I have an alternator about to take a dump
Last edited by appliancguy; Aug 16, 2011 at 10:50 AM. Reason: needed proof reading
Old Aug 16, 2011 | 12:03 PM
So by 1 wire, you mean a +12V 10ga wire + another smaller wire right? If that is the case, then the problem is likely due to a problem with how the PCM is controlling the alternator. This can sometimes be caused by an internal problem with the PCM that causes a delay in the field control signal to the alternator. One thing you could try is a rewire on the alternator to turn it into a battery reference control rather than a pulse width modulated field control as it is now.
Convert Alternator from PWM to Battery Reference
Since you only have the one wire already in the 'B' cavity of the connector, you only have to add the wire to the 'D' cavity that will run back over to the B+ stud on the back of the alternator.
Old Aug 16, 2011 | 08:16 PM
Default ok
So the one wire is coming from the PCM. I'm going to wire the internal reg for voltage all the time but its doing nothing until the alt is spinning??
I was idling for 45 mins with a/c head lights blower running and hit the window....died. Had to jump it. I may get an AD244 tomorrow and end it...want electric rad fans but gonna need juice for those.
Old Aug 16, 2011 | 08:38 PM
Yes, the alternator in your truck is PCM controlled. You could take the alternator into a decent auto store and have it tested.
You wouldn't be disappointed by a AD244 swap though.
Old Aug 16, 2011 | 09:27 PM
Check out Painless #30705 Simple picture and instructions
krallstar
Oct 4, 2011 03:45 PM
b4mp3r
May 7, 2009 05:26 PM
leglgtabiz
Performance & Brainstorming
Feb 24, 2009 07:37 AM
PABlazer
Dec 10, 2008 02:31 AM
dbleon
Dec 29, 2007 06:04 PM
