Alternator issues
Old Jun 28, 2011 | 04:45 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
Default Alternator issues
I am looking for someone who knows how the vehicle control module and instrument cluster work together to control the alternator. I have a 97 Blazer that stops charging at 4000 rpm. As soon as the rpm drops below 4000 the alt starts to charge again.
The alternator checks out. The signal to the alternator actually disappears.
I have an electronics background but do not know what sort of logic is actually taking place in the instrument cluster and VCM. I am familiar with Bolean algebra so if some GM elctronics engineer has hijacked logic diagrams I can read them! LOL!
Thanks in advance!
Old Jun 28, 2011 | 06:58 AM
On the '98_ trucks, the field is controlled by the PCM through a PWM (pulse width modulated) signal. Looking through the wiring diagrams for a '97, it appears that they are setup as a reference voltage. I would look at what is happening on the gauges fuse and check to make sure that the resistor in the cluster is intact.
Old Jun 28, 2011 | 09:27 PM
kristoph30's Avatar
Thanks! I am just coming off a mid-shift so I will probably tear into it tomorrow. Thank you for the wiring diagram! My diagram for the 97 didnt show the resister in parallel with the indicator light or give its value.
Have a good one!
cdubbin90
Jan 23, 2015 11:40 AM
daemeon2
Jan 6, 2013 04:06 PM
lionel2
Aug 17, 2012 07:32 PM
cruukedeye
Jun 4, 2011 06:49 PM
cochran07
Feb 24, 2011 12:25 PM
