ANOTHER blown rear wiper motor
Old Feb 16, 2011 | 03:15 PM
ComputerNerdBD's Avatar
ComputerNerdBD is on a distinguished road
Default ANOTHER blown rear wiper motor
I replaced the rear wiper motor last year or the year before because the old one froze and did not have the power to start up anymore. As far as I know, this one is a reman motor. Today, I hit the switch to turn it on and all it does is vibrate, move a bit and get stuck. It is definitely broken. What could be wrong with this one and how do I prevent it from happening again? Should I be getting a Dorman motor from RockAuto for the $50 or buy a more expensive motor?
Also, I broke the trim panel where the screw is when I changed it last time since the glass would not open (water got into the lock switches, so I had to pull the fuse for it, which also took out the glass opener). How do I fix it? Epoxy? Also where can I get the light switch that is attached to the bracket? I also broke the tab that holds the wire into the switch.
Old Feb 16, 2011 | 04:08 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
it sounds like the gears in the motor are stripped....i would invest in a higher quality part... heres a new motor.... not a reman... http://www.napaonline.com/Search/Det...+50030+2030009
limited edition 1
Jan 27, 2023 11:07 AM
WhiteNoiz
Jul 31, 2009 10:55 PM
Shabba
Apr 4, 2009 02:50 AM
BlazerRomone
Jul 16, 2007 06:54 AM
GMdesigner
Jul 12, 2007 12:23 AM
