Auxiliary light help!
Old Dec 6, 2014 | 08:44 PM
Ciarra Larson's Avatar
Ciarra Larson is on a distinguished road
Default Auxiliary light help!
The Blazer I just bought came with lights on the grille guard. Wired them up to the high beam light (or so I thought) and now when I drive it they stay on all the time, even with the high beams off. Is there any way around this? I have the DRLs and no factory fogs. I want them to run on high beam only.
Old Dec 6, 2014 | 09:15 PM
richphotos's Avatar
try pushing your parking brake pedal in a couple clicks and see if your DRL's shut off and the off road lights shut off.
If they do, I would guess you tapped into the wrong wire.
Also, how many aux lights are on the grille gaurd and what watt are they. Chances are the factory wiring cant handle the extra load.
you would be better off wiring them off the battery with a switch and a relay. There are quite a few threads on this forum on how to do that.
Old Dec 6, 2014 | 10:37 PM
rexazz2's Avatar
all of this plus you could trigger the relay with the high beam + if you want them only to come on with the high beams
Old Dec 7, 2014 | 07:48 AM
rexmburns's Avatar
Super Moderator
Not to mention it's illegal in many states to have aux lights on when your high beams are on. I don't know where you live tho so can't say for sure!
wlorton
May 4, 2017 08:15 AM
Manatee
Jul 24, 2011 05:42 PM
pctechdude
Oct 28, 2010 01:18 PM
SJG89
Mar 19, 2009 07:55 AM
basketballmail2
Jul 11, 2008 08:44 AM
