Battery dead every morning
Old Sep 25, 2013 | 07:42 PM
cking192's Avatar
cking192 is on a distinguished road
Default Battery dead every morning
I haven't driven my blazer much, but whenever I try and start its as if there is 0 charge in battery. When I turn the key no dash lights turn on, and I can't even use the power locks. I just replaced the battery and the alternator about 2 months ago.
I'm guessing there's some kind of ridiculous battery drain on it, but I can't figure out what it could be. I've had a 550 watt amp connected for about 5 years and I've never had this issue. AAA came and it started right up just fine and ran no problem with around 13 - 14 volts. But... the next day it was completely dead again.
Any ideas on what could be draining my battery? If I went to autozone could they test it to see what is draining my battery?
thanks
Old Sep 25, 2013 | 07:55 PM
dpmeeks's Avatar
dpmeeks is on a distinguished road
finding a battery drain can be tough. After you jump and get it started does it stay charged rest of the day ? Will it start the next day without jumping ? You can try to isolate the problem by pulling one fuse at a time. Did you have the problem before changing the alternator and battery ? If not, it could be a bad battery. I would take the battery to a-zone and have them charge and test it.
Old Sep 25, 2013 | 08:38 PM
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
I've had the same issue on other Chevy vehicles so I knew what to look for on my blazer I have now. Next time its dark and ur in your blazer and if you have vanity mirrors in your visors a lot of times they never shut off even tho they are up I guess sometimes the pin breaks or sticks and the light stays on killing the battery and if there folded up you would never see the lights on
Old Sep 25, 2013 | 09:01 PM
wheeliemay's Avatar
wheeliemay is on a distinguished road
I have had a bad battery do this. It was particularly tough becouse it would go ok if it was driven frequently--but a couple days in the garage and no start...shop would test it (couple times) and said it was good then I said just replace it and no problem since.
Also, check for underhood light--I have had that get me before on an old Buick.
Old Sep 25, 2013 | 09:08 PM
richphotos's Avatar
*Moved to Lighting & Electrical"
Old Sep 25, 2013 | 09:14 PM
cking192's Avatar
When I replaced the battery/alternator it worked fine for about a month. Then when I used it less frequently it started doing this. I havent tried starting it the same day but yes, its dead the next day. I could see it being one of those but I may have to test the fuses. I'll let you guys know.
Thanks
Old Sep 25, 2013 | 09:23 PM
chris015's Avatar
Old Sep 26, 2013 | 10:38 PM
cleburne red's Avatar
Just get in the habit of yanking off the negative cable every time you park for the night!
Definitely have auto zone or wherever test the battery and alternator both. If both test ok, then you get to search and find out what's staying on. One fuse at a time.
Old Oct 23, 2013 | 07:55 PM
necropenetrator's Avatar
necropenetrator is an unknown quantity at this point
lol i was going to say vanity mirrors also... been there! removed bulbs! chevy passenger vanity has broken in every blazer and the malibu i own!
Old Oct 27, 2013 | 12:08 PM
gpgab97's Avatar
gpgab97 is on a distinguished road
Vanity mirror here too.. I wedge something in between the switch on the visor and the headliner to shut it off.
94s10blazin
Aug 10, 2013 01:00 PM
MENOMON
Jun 1, 2011 09:11 AM
live4liftin4848
Jan 2, 2010 10:59 PM
rriddle3
Aug 26, 2007 04:38 PM
brownblazer
Sep 12, 2005 06:55 PM
