Battery draining all the time.
Old Jun 16, 2011 | 09:08 AM
ghostsoldier's Avatar
ghostsoldier is on a distinguished road
Default Battery draining all the time.
Hello all, I have a 1991 chevy blazer. I recently got the engine rebuilt and since then the battery will be totally drained if i let it sit there and dont run it fo a day or two. I've had the alternator tested and is OK, the battery is brand new also. Is there any way to test for an electrical leak? Or is there something I can check for that im missing? Any help at all would be appreciated.
Old Jun 16, 2011 | 09:13 AM
Plenty of ways to test for a amp draw. On an older vehicle, it has to be something pretty simple. Use a multimeter set to the amp scale. Remove the fuses one at a time and put the leads from the multimeter into the terminals in the fuse box. Record the values for each fuse. You should find the source of your draw that way. If you don't, then it is something that isn't powered through the fuse box.
tmay2
Jan 15, 2010 08:52 PM
tnw912
Jan 5, 2010 05:27 PM
brightside
Dec 16, 2009 10:50 AM
kiwiblazer
Oct 21, 2008 01:14 PM
BradN10
Jul 22, 2006 10:58 PM
