Battery/starting issues
Old Oct 11, 2011 | 08:59 PM
19echo95's Avatar
19echo95 is on a distinguished road
Default Battery/starting issues
Hey guys, I have a 2000 Blazer LS that had the previous battery ran dead because someone (not me) decided to sit in the Blazer and listen to music for about an hour which of course F'ed up the battery. So, we bought a new one and now every time we attempt to start it it won't start. It acts as if there is no battery hooked up, but if we open the hood and move the battery around it will start (the battery gets moved around while driving). But starting today whenever it won't start like it's supposed to I get out and move the battery and it attempts to start but it sputters a few times before it will start, or it will start then turn off. It's getting quite annoying and I don't enjoy making an *** out of myself when in a crowd and trying to get out of somewhere.
So, does anyone know how to prevent this from happening? I'm about 3 seconds away from going and getting some really big zip ties and strapping it down to the battery holder.
Oh yeah, speaking of battery holder; the little rubber/plastic piece that is made to help the battery stay in place is still there and pushed as far as I could against the battery. Also keep in mind that this never happened until we got this new battery.
Old Oct 11, 2011 | 09:10 PM
69chevelle's Avatar
69chevelle is on a distinguished road
If your battery isn't tight with the back side 'slid' under it's 'holder' and the front side tightended down, that tells me you bought the wrong battery.
One reasons it could sputter sometimes and die when you start it is because if your pcm doesn't have power for x amount of time, it will 'forget how to run'
My suggestion would be to make sure your terminals are tight, and if they are, remove them, clean them and re tighten them. keep in mind they don't have to be very tight.... Also make sure the rubber 'protective part' isn't caught between anything.
Old Oct 11, 2011 | 09:15 PM
19echo95's Avatar
Ok, I will try that first thing tomorrow. I'm about 98% sure we bought the right battery. I will have to check but I don't think that's it.
1998mom
Jul 25, 2013 09:43 AM
TigaHotty85
Jun 17, 2013 03:10 PM
chevyman93
Dec 17, 2012 05:59 PM
tnw912
Jan 5, 2010 05:27 PM
lukewb
14
Dec 2, 2006 02:23 AM
