bcm swap?
Old May 24, 2011 | 01:50 PM
jackdough's Avatar
jackdough is an unknown quantity at this point
Default bcm swap?
im trying to get keyless entry in my 2000 jimmy that never had it before. done a lot of reading, and have a pretty good idea of what im doing. my only question is, instead of paying the stealership to program my bcm to recognize the rke can i swap the bcm out of the donor truck (same year) without running into problems? thanks
Old May 24, 2011 | 01:53 PM
If I remember correctly, the replacing of a BCM and/or PCM requires programming to match the remaining component. If you just swap the BCM, the PCM may lock down, resulting in an inoperative vehicle until you get them acquainted (programmed). So in the end, programming is required so why not just get the BCM programmed to recognize the RKE!
Old May 24, 2011 | 02:00 PM
jackdough's Avatar
i was afraid you would say that lol. i had read about guys paying $250 to have it programed, and with a new baby almost here thats not gonna happen. guess ill just stop in and see what they are going to want for programming. if not try to find a buddy with tech 2. once again thanks for the quick reply swartlkk
tim153
Feb 22, 2013 02:49 PM
skygodtj
Apr 18, 2012 05:19 PM
midnightbluS10
Dec 7, 2010 06:47 PM
Angel Blazer
Dec 27, 2008 02:27 PM
uncthaddeus
Feb 20, 2007 11:45 PM
