Blinkers drawing THAT much current?
Old Dec 21, 2013 | 09:41 AM
Badco's Avatar
Badco is on a distinguished road
Default Blinkers drawing THAT much current?
Hey guys, small question. No biggie, but I had my blinkers on just after I replaced my alternator and the Voltometer started wobbling (At the time I thought this was going to be a spaz attack, so I just turned all my electricals off)
Yesterday I just happened to notice it again and the blinkers were on and the voltometer was acting a little crazy.... so I shut them off, drove to my apt and tested them. Yupp. Blinkers.
See I'm not quite seeing here why I can have absolutely no change in voltage when I'm running the subs pretty high, but two measley blinkers are drawing about .75-1.5 volts. Does anyone else notice the vGauge doing this with their blinkers? I don't remember this happening with the other alternator.
Old Dec 21, 2013 | 11:20 AM
richphotos's Avatar
Does your truck have grounds for the blinkers? or is it grounded in the PCM.. if it has grounds up on the firewall, could be the problem.
Old Dec 21, 2013 | 11:59 AM
Badco's Avatar
Are the firewall grounds prone to corrosion? I can't go digging in because it's raining. If it stops I'll probably hit wallyworld and grab a pack of o-rings and wire up a secondary ground.
But if it's a PCM, what could I be looking at here?
Old Dec 21, 2013 | 12:41 PM
richphotos's Avatar
To be honest. I dont know. I am not knowledgeable on second gens. But blinkers should not make the voltage drop like that unless there is a short or ground problem.
Have you checked the bulbs?
as for the grounds on the firewall IF you have them... they can get corroded, just like any other ground.
Old Dec 21, 2013 | 08:29 PM
warthogdriver's Avatar
Mine have been doing this for couple years...just got used to it. If you find an answer be sure to share
Old Dec 21, 2013 | 08:41 PM
Badco's Avatar
I'll tinker around and see what I can. I'm a starting off backyard mechanic so I'll probably end up breaking something lmao. Could just be the new alt responding better. But I'm not sure why the blinkers do this and the 350 bpm double kicking bass dropping infant annihilator doesnt even phase the voltogauge.
Blazer mystery! Must have been one of special Daves engineering quirks.
lalypsimmons
Jun 26, 2014 01:27 PM
BigEffingHammer
Oct 14, 2011 07:14 AM
gcg
Dec 10, 2010 02:58 PM
hidextra.com
May 12, 2010 05:24 PM
rlb
Nov 24, 2007 06:33 PM
