Blower Switch
Old Mar 20, 2011 | 02:03 AM
clbychil's Avatar
clbychil is on a distinguished road
Default Blower Switch
The blower on my AC only works on setting 4. 1,2, and 3 do not work at all and when I turn it to 4 it blows full blast. Its a little annoying and I dont know what to do.
Old Mar 20, 2011 | 05:52 AM
JandL_03's Avatar
JandL_03 is on a distinguished road
2 things....could be either your switch itself not noticing to switch levels and you need a new switch...or its your cable that adjuststs from hot to cold...it might be called the temp door or blend door cable..something along those lines...fyi..not that expensive of a fix
Old Mar 20, 2011 | 09:12 AM
Classic symptoms of a bad blower motor resistor pack.
Which truck are you working on? Your sig says '99, but your garage link under your username says 1991...
Old Mar 20, 2011 | 04:56 PM
rob180's Avatar
rob180 is on a distinguished road
Blower motor resistor, bout 40 bucks at autozone if I remember correct. Gotta lay on your back and take out the blower motor to get at it.
Old Mar 20, 2011 | 05:16 PM
If we're talking about his '99, it is accessible under the hood on top of the HVAC box.
Old Mar 20, 2011 | 05:19 PM
rob180's Avatar
Yep, didnt see that.
Old Mar 20, 2011 | 07:05 PM
clbychil's Avatar
Yeah its my '99. Is this a relatively simple fix? I'm not a very experienced mechanic and know very little about this problem.
Old Mar 20, 2011 | 07:14 PM
Are there numbers around the temperature **** on your HVAC controls or just blue & red? If blue and red, yes, it is simple. Worst part is that you'll have to cut the protective rubber cover over the HVAC housing under the hood. Use the search function to find further details. A term like "blower+motor+resistor+replace" should get you the results you are looking for. There is even a how-to in the Tech Article (DIY) section.
maxvamp
Oct 31, 2020 08:19 AM
JFD444
Dec 5, 2011 01:02 PM
dannybva
Jan 11, 2011 12:35 AM
SWATPARAMEDIC
Jan 1, 2010 03:12 PM
lawarf22
Jun 22, 2006 07:44 PM
