Body relay block location, removal & schematic
Old Sep 18, 2013 | 10:45 AM
Jamaroon's Avatar
Default Body relay block location, removal & schematic
When I was searching for information on what relays are in the body relay block, I came across numerous threads asking about its location and how to get it out. I figured since my dash is out I'd take a few pictures showing how it's attached to try and help people get an idea of what they need to do to remove it.
It uses plastic clips and attaches to some holes in the pedal assembly bracket.
You have to push the bottom two clips down
The top two are hooked downward, so once the bottom is unclipped, you have to push the relay block up and towards the front of the vehicle.
Then you can pull it down, remove the cover and access the relays
I found this diagram online after some searching
(1) Park Lamp Relay
(2) Courtesy Lamp Relay
(3) Retained Accessory Power (RAP) Relay
(4) Power Seats Circuit Breaker
(5) Power Windows Circuit Breaker
(6) Inadvertent Power Relay
(7) Door Lock Relay
(8) Headlamp Ground Relay
(9) Driver Door Unlock Relay
(10) Door Unlock Relay
Attached Thumbnails Body relay block location, removal & schematic-5a3d9595-0b7c-4228-bbfa-08390cfd53fd-4359-0000074310fcce90_zpsa4681dbc.jpg   Body relay block location, removal & schematic-b3113ca3-febf-4b68-86d6-61e8579fa53b-4359-0000074319af7f6c_zps40e17713.jpg   Body relay block location, removal & schematic-483c5bfb-00bb-4578-9bdc-750cd69ff8e7-4359-0000074329f6d861_zps0f089f0b.jpg   Body relay block location, removal & schematic-d00db8a2-5e39-4526-b2df-42cfdd0b6f26-4359-00000743213ce2c9_zps1244e211.jpg   Body relay block location, removal & schematic-b1d8d9a4-f384-4d68-8649-443faf025575-4359-0000074330de83c0_zps74bb0c91.jpg
Body relay block location, removal & schematic-b3aa6f3f-59ee-4a74-92d7-544afb873219-4359-0000074336ed0c14_zps4634823e.jpg   Body relay block location, removal & schematic-a5c162e0-3473-4cf2-a2c6-044f488f867d-4406-00000750a2545b19_zpse540f263.jpg
Old Nov 10, 2013 | 06:32 AM
R007's Avatar
R007 is on a distinguished road
I had a problem with the tail light on my 1999 model Blazer (brake lights and turn lights worked, but not the main tail lights). I searched for the body relay block behind the panels below the instrument panel/on the drivers side in order to check the Park Lamp Relay which seems to be part of the circuitry for the tail light. Then I found a box labelled "Runninglight EB701" next to the steering column that contained three fuses. A 10 A fuse was broken. Once it was replaced my rear lights worked again.
Since I live in Norway I guess this may be a modification for European and/or Norwegian vehicles. But I mention this in case it is of help to someone.
Old Oct 14, 2014 | 01:22 PM
TheDirtyDime's Avatar
TheDirtyDime is on a distinguished road
Default Awesome
just wanted to say I have been looking for pictures like this for way too long trying to get mine out. Wanted to let you know your post greatly helped me!
Old Oct 15, 2014 | 11:04 AM
Jamaroon's Avatar
Glad it helped!
Old Sep 20, 2015 | 01:05 PM
Bravadaboss91's Avatar
Bravadaboss91 is on a distinguished road
Is it necessary to remove the entire dash just like in the above pics to get to the relay block? Or is it possible to just reach up there?
Old Sep 20, 2015 | 01:20 PM
Jamaroon's Avatar
You should be able to get to it with the dash in place. I had my dash out because I was swapping interiors and took some pictures because everything was easy to see.
masterchf117
Oct 31, 2021 11:03 AM
lil_blazin
May 10, 2009 05:20 PM
celchlepp
Nov 18, 2008 11:16 AM
bestes
May 31, 2008 03:16 PM
RCarp48
Apr 2, 2007 07:19 PM
