brake light problem need help
Old Apr 22, 2014 | 06:53 PM
Talenmcd's Avatar
Talenmcd is on a distinguished road
Default brake light problem need help
Hello guys I need help i have a 88 S1I blazer 4.3, the problem is my brake lights aren't working i've checked fuses and my bulbs. iv'e changed the multi-function switch and bulbs and i'm stumped any help would be great.
Old Apr 22, 2014 | 06:57 PM
richphotos's Avatar
Do the parking lights work? I would start checking the brake light switch under the dash
Old Apr 22, 2014 | 06:59 PM
Talenmcd's Avatar
Yes the parking lights work. where is the brake light switch located?
Old Apr 22, 2014 | 08:15 PM
erics9971's Avatar
erics9971 is on a distinguished road
It is usually located at the end of the brake pedal. Basically it is a little sensor the tells your lights that your brake pedal has moved. sometimes they need to be re-adjusted. My brother had the same problem on his car. Just make sure to not over correct it because your lights will stay on non stop even with the key out.
Old Apr 22, 2014 | 08:36 PM
richphotos's Avatar
its located under the dash behind the brake pedal. if you are looking up under the dash, at the brake pedal/arm. The switch should be gray or white
Doggpool
May 24, 2011 08:17 PM
jdm2004
Feb 22, 2011 12:30 AM
beastbandit92
Aug 13, 2010 08:24 PM
SCBlazer96
Apr 16, 2010 08:39 PM
xderkax
Jan 14, 2010 11:38 PM
