Brake light problem...help!!!
Old Mar 14, 2010 | 11:06 AM
jdm2004's Avatar
jdm2004 is on a distinguished road
Default Brake light problem...help!!!
I have a 94 full-size blazer, 5.7L, no significant modifications. The brake light fuse keeps blowing within minutes of replacing. Bulbs are fine. Tail lights work fine when lights are on and the blinkers are functioning fine. My hazard lights have not worked for some time. I read that the hazard and brake lights run thru similar wiring pathways.....should I replace the hazard switch or look elsewhere for the brake light fuse problem?
Just waiting to get pulled over for no brake lights,
JDM
Old Mar 15, 2010 | 11:18 PM
oisinirish's Avatar
Have you checked he brake switch? it may have a short?
Hazards work fine without tripping said breaker?
Electrical problems can be lots of fun.
Old Mar 16, 2010 | 01:05 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
You may have a problem with the hazaed flasher. Have you replaced it? I think they are probably two different flashers that end up running the same lights. I also agree on the switch. If you have cruise control there are two brake light switches that both have to be adjusted correctly.
Old Mar 20, 2010 | 12:03 AM
SWATPARAMEDIC's Avatar
SWATPARAMEDIC is on a distinguished road
Might also check your wiring to the lights from the fuse box to the lights. I had a similar problem with right brake and turn signal light. Turned to the the wire rubbing on he edge of the fender and it actually cut the wire. Put a butt connector splice and then covered the wires and no problem since.
Old Feb 22, 2011 | 12:30 AM
95redblazerelectrwhiz's Avatar
95redblazerelectrwhiz is on a distinguished road
hey i had a similar problem with my 95 blazer 4.3 vortec. my brake lights didnt work neither did my hazards. it is that turn signal multiswitch on the steering column. you do not need to take off the steering wheel just the steering wheel shroud. for that you are going to need torx bits and inverted torx bits. its not that complicated just a few screws and some finangling but it is not that hard. the brake lights run through that assembly so if the hazard flasher relay goes bad in that assembly its not allowing electricity to flow through to engage the brake lights or hazards. my first thought was the brake switch. wrong.... thanks to gm making one part do 50 different things the part costs a little bit. im normally a ford guy this is my first chevy and i like it so far because i have always somewhat liked the blazers but overall easy fix just not so easy on the wallet. hope this was helpful!
Talenmcd
Apr 22, 2014 08:36 PM
Doggpool
May 24, 2011 08:17 PM
beastbandit92
Aug 13, 2010 08:24 PM
SCBlazer96
Apr 16, 2010 08:39 PM
xderkax
Jan 14, 2010 11:38 PM
