Brake lights stay on
2000 GMC jimmy, brake lights stay on with the ignition. I have checked all the fuses and replaced the brake light switch to no avail-
Other unusual conditions are the car has power when the brake pedal is depressed even without the key in the ignition. Also the right turn signal is not working.
To clarify, the brake lights are always on when its running, whether or not the pedal is depressed.
Even with the key out of it when you press the brake pedal, the dash lights, radio, fan, etc. are powered up.
Well after checking every fuse, I did some wiggling and jiggling of the hazard switch and the brake lights went completely out, the chmsl returned to normal operation,and the turn signals will work erratically if you wiggle the hazard switch.
Also, it no longer energizes the car when you press the brake pedal.
I am kind of thinking of just changing the hazard switch first.
Any thoughts?
Any thoughts?
Steven S. Acedo
May 10, 2012 05:28 PM
