bumper lenses 1997
attempting to replace bumper lenses 1997 zr2. should be a simple task, however is proving to be the opposite. anyone know an easy way to access these?
u mean your lower turn signal/marker lamp, u should be able to lay under the truck and just look right up at it, then remove 2 8 or 10mm bolts, disconnect the wire to the light itself and it should come right out. Let me know
ive managed to get it all unhooked, however there is no room between the bumper and the radiator, between wiring harnesses and supports for the bumper and radiator, to wiggle it out.
