a/c heat control switch issues
Old May 24, 2012 | 11:33 PM
volunteerff's Avatar
volunteerff is on a distinguished road
Exclamation a/c heat control switch issues
wondering (before i buy) if anyone on here would have any idea on what this could actually be instead of throwing money at it. But what could be the issue of air coming out but only on "DEFROST" nothing else. It will not come out on the body vents just the glass vent for the windshield and the floor. Any ideas?? When i changed the heater core i also changed the blend door. Everything was hooked back up exactly by a friend who is ASE CERT. He asked me if the switch worked before we did the swop, and infact yes it did. There is nothing blocking the vents.... ANY IDEAS anyone please!!!
Old May 25, 2012 | 06:36 PM
abig84's Avatar
most vehicles when they have no vacuum going to the control head will default to defrost. soooo i would start there, try to find the line going into the firewall. see if it has it there, then maybe at the control head then at the actuator under the dash, if you can get at it
unless you have electric controls then ignore all that but pretty sure s10 heater controls are vacuum
Old May 26, 2012 | 03:57 PM
burt222's Avatar
burt222 is on a distinguished road
my heater was stuck on high heat and only worked on defrost because of a bad heater resister, cheap and easy fix under and hour and less than $20
good luck
Old May 27, 2012 | 05:19 AM
Do you think that could be the issue though @burt222??? I have my A/C hook up and recharged by the same friend and it still works. I use it daily now because its starting to get warmer here in central pa. Also @abig84, I have not checked the lines yet, I will check them today as far as I can trace them. I have no idea where the line would be under the dash, but I guess when im looking at it, Ill figure that out. LOL.
Old Jun 23, 2012 | 09:26 PM
Sorry for the delayed response, but it was the vaccum lines. They were all rotted a and falling apart as i pulled them out of the engine.... but new issue, or is this normal, but whenever I am driving and I take the rpm's over 2000-2500 i lose vent flow and it defaults to defrost.... any ideas or is that normal for a 95' ls blazer???
Old Jun 24, 2012 | 08:28 AM
Sounds like the check valve in the system either isn't installed or isn't working properly. It should prevent low vacuum pressure in the engine (i.e. when under acceleration) from affecting the vacuum pressure in the HVAC & 4wd (if equipped). It should be installed to allow the engine to pull a higher vacuum on the HVAC/4wd system and allow the vacuum to stay in that system if the line between the engine & the check valve gets disconnected.
Old Jun 25, 2012 | 02:40 PM
Okay sooo where is that loacated??????
Old Jul 11, 2012 | 01:40 AM
so i think i changed the right part called the check valve, it had three vaccum lines going into it. buttttt i still lose air out of my vents at 2000+ rpms... anymore ideas????
Old Jul 11, 2012 | 08:02 AM
If the check valve didn't cure it and it is installed correctly (single port side towards engine, double port side towards vacuum accessories), then you have a leak somewhere in the vacuum lines.
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
cide
Nov 8, 2010 08:17 PM
mcaanda
Dec 15, 2009 08:31 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
