A/C not working 2000 Chevy blazer ZR2
George
- Pull the relay and with the ignition off, find out which socket has continuity with the dk green wire at the compressor
- Then turn the ignition on and find the two sockets with 12v
- The remaining socket is the control line from the pcm for the low side relay coil control
If you have an led test light (not incandescent) then clip to battery positve and probe that control socket and see if it lights up with a call for cooling. If you dont have that test light type then put the meter in dcv and connect between battery positive and that socket to see if you get a steady 12v during a call for cooling.
George
OK then now we need to test the ground side control of the relay from the PCM but first we need to identify the relay socket contacts:
George
George
George
alrighty, I have a multi meter and a test light, I haven’t used the multi much but I’m sure I can figure out how to do resistance and low scale. Thank you again will post results tomorrow
(Help! 2000 blazer ZR2 AC doesn’t work
It sounds like you might have a problem with the AC system. First, check the AC fuse and relay in the fuse box to make sure they’re not blown. Next, inspect the AC compressor to see if it’s engaging; if not, it could be a sign of a low refrigerant level or a faulty compressor. You might also want to check the refrigerant pressure using a gauge. Finally, look for any visible leaks in the AC lines or connections. If these steps don’t solve the problem, consider having a professional diagnose the issue.
Below is the wiring diagram for the automatic control hvac (ECC or Electronic Climate Control) option. This schematic came from alldatadiy when I had an account for my old 2000 Bravada. If you have the manual hvac option, someone would need to provide the appropriate schematic.
Automatic Controls (ECC):
Let us know how you make out on your review of the wiring. Circuit integrity checks should include:
- AC Relay trigger to PCM/VCM
- PCM/VCM thru high pressure switch to ECC (if so equipped)
- PCM/VCM thru low pressure (cyclinng switch) to ground.
mharrison
08-27-2019 01:23 PM
fresh931@yahoo.com
05-27-2018 07:33 PM
stokedstephen
09-28-2016 09:26 PM
