chasis wiring harness problem
I sorta had the same problem. I switched my 2 door from manual to power by changing the harness. From my experience you have to use the same year and your PCM and BCM in order for the swap to work. I also had a 4 door donor harness in mine for a while and it was a 4wd harness it was just a little longer... Lol. But when I found the correct harness it worked great now I have power everything. I can take the dash assembly out in about 20 min now! Good luck!
phxjosh
10-30-2013 10:03 AM
lowloudnproud1
09-02-2010 07:12 PM
trapper_canada
08-15-2005 11:33 PM
