Clear corners and fog lights?
Old Dec 27, 2011 | 08:19 PM
Fourstar200's Avatar
Fourstar200 is on a distinguished road
Default Clear corners and fog lights?
Ok guy so I have a 99 2wd 4dr with the factory fog lights. I was wondering if anyone knew of somewhere that I could get clear turn signals that fit with the fog lights? Thanks.
Old Dec 27, 2011 | 08:24 PM
Have you checked eBay? You would probably find the lowest prices there.
If you can't find the two piece clear outer housing, the clear single piece housings can be modified by adding the mounting lug from your current turn signal housing to the fog location.
Old Dec 27, 2011 | 09:32 PM
mdehoogh's Avatar
I haven't checked in years but APC used to be the only company that made any and they were discontinued years ago.
A member here (JST4SHO) has a set on his Blazer.
Old Dec 27, 2011 | 10:11 PM
Here's a set --> 98-04 CHEVY S10 BLAZER CLEAR PARKING TURN SIGNAL LIGHTS fogs & all!
Not sure if this set has the proper fog socket on it, but looks like it --> 98-04 Chevy S10 Pickup/Blazer LED Bumper Lights+SMD LED
Kind of expensive, but there are a few options with just a few searches..
Attached Thumbnails Clear corners and fog lights?-%24-kgrhqqokj4e2bv10ylnbnin9mhtd-%7E%7E_12.jpg
Old Dec 27, 2011 | 10:46 PM
Thank you guys so much! I searched eBay I must not have used the right word choice or somethig.
Old Dec 27, 2011 | 11:01 PM
How exactly would I go about modifying it to make them fit? I'd rather pay less and do some modifying then pay 100 buck for them :-)
Old Dec 28, 2011 | 12:41 AM
You would basically have to cut out the part of your current fog lights that mate to the bulb, then drill a hole in the center of the inner reflector of the replacement housing & epoxy on the bulb mount onto the back. Do some trial fits to get the beam pattern as close to stock as you can, both in elevation & location before gluing it in.
Mr Blazer LT
Aug 12, 2009 12:12 AM
OILCOUNTRY
Feb 27, 2009 02:46 PM
jhoe414
Oct 12, 2008 11:28 AM
92txblazer
Detailing
Aug 13, 2008 11:02 PM
Blaize70
Dec 24, 2004 02:25 AM
