Code 43 (and 24) on Hard Acceleration only
Old Jul 17, 2021 | 10:23 PM
dakovac's Avatar
dakovac is on a distinguished road
Default Code 43 (and 24) on Hard Acceleration only
I've got a 1990 K5 Blazer with a 350 cu in TBI equipped engine. I used to get a code 43 before I got the main harness fixed but now I got one as I was trying to accelerate on the highway, I also got a code 24 too in that instance. If I only get a code 43 on hard acceleration is that a cause for concern? Could I somehow test the ESC module and sensor? Also is the code 24 vehicle speed sensor a dire issue as well?
Thanks.
Old Jul 19, 2021 | 01:19 PM
Does your speedometer work? I believe the VSS for that year is in the cluster and is driven by the speedo cable.
The code 43 can be caused by a faulty knock sensor. I don't know of any way to check the ESC module other than "replace with known good part".
Old Jul 19, 2021 | 03:53 PM
dakovac's Avatar
The speedometer works perfectly fine which confuses me even more, I guess both of them were false positives because I drove today and the error codes did not activate.
Old Jul 19, 2021 | 05:00 PM
Sounds like it fixed itself. If only they could all be that easy...
Old Jul 19, 2021 | 05:21 PM
I'm still waitting for my driveline to swap itself lol
Glad it went away... hopefully it doesn't come back
mirandaneon
Jul 4, 2013 11:29 AM
Helter80
Apr 24, 2013 09:37 PM
92s10Blzr
Dec 7, 2009 03:12 PM
BABs
Aug 16, 2009 04:35 PM
firststep
Aug 12, 2006 05:10 PM
