Compustar Remote Starter Issue.
Old Feb 10, 2011 | 09:10 PM
streblo's Avatar
Default Compustar Remote Starter Issue.
So ive had a compustar remote starter in the blazer now for 3 or 4 years.
This morning it decided it wanted to act up.
When i went to leave this morning i hit the command start and went outside and, well no start. Went to turn the key and heard the tick tick tick of low voltage. So threw the battery charger on, and at 10a charge just that bit extra help from the charger the blazer started.
So i made it to work, leaving work tonight i hit the command start and got NOTHING from the blazer, no sounds, no lights, nothing. Went and turned the key and started no problem.
So the remote start is not working, with either fob.
BUT the door lock and unlock works.
BUT when i lock the doors the parking lights would normally flash, I was getting no flashing from the parking lights when i locked or unlocked the doors, although the lock and unlock function was working properly.
On an unrelated (or possible related) note. My parking brake light came on the other day and went away...few days later it came back on again, and when making a sharp right turn the light goes off, then comes back on again. So not sure if this may be a related short or not.
So im thinkin i have a short somewhere that is not allowing the starter to work, and was thinking draining the battery, BUT after sitting for 8 hours today the blazer started no problem, after only running for 20 minutes after starting it with assist from the charger.
Any thoughts of what it might be or where to start looking?
Old Feb 10, 2011 | 10:56 PM
streblo's Avatar
..DUH....that was a MAJOR brain fart........problem solved.
SOMEHOW it got itself in valet mode, so turned valet mode off and good to go.......apparently in valet mode the lights dont blink either.
Still have to figure out the parking light but thats probably the switch and ill just over ride it because i dont care about it....but still weird why the battery was low this morning!..HMM......
But ya, Starter problem fixed.
Old Feb 14, 2011 | 10:16 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
It's common for a remote start to lose it's programming or go into valet when a low or dead battery happens.
Old Feb 14, 2011 | 11:55 PM
streblo's Avatar
ya, i remember i went through this exact same thing like, 2 years ago, with the lights not flashing and everything and just,,,,major brain fart, didnt even remember at first!...now to figure out this stupid battery, went low 2 mornings and been fine ever since.....damn gremlins
Old Feb 18, 2011 | 09:21 AM
streblo's Avatar
The battery issue:
So ive decided that the battery is shot.
2 days 2 weeks ago when temps were below -15 it wouldnt go in the morning.
all last week was above -10 and had no problems all week.
This was the first morning since that temps were below -15, and again a no start in the morning.
So back to can tire for my second free replacement!
ComputerNerdBD
Oct 16, 2011 06:10 PM
viper4559
Dec 17, 2009 08:01 PM
salvy
Nov 14, 2008 07:24 PM
davtak
14
Jul 9, 2007 04:03 PM
davtak
May 27, 2006 06:00 PM
