constant clicking under dash
Old Jan 10, 2013 | 09:45 AM
beehall's Avatar
beehall is on a distinguished road
Default constant clicking under dash
My 2001 blazer clicks quickly and repeatedly constantly when at idle and slightly above. It does sound like a relay and appears to be behind the instrument cluster. What should I be looking for?
This occurs only when running and stops when the engine speed is above an idle.
Old Jan 10, 2013 | 10:19 PM
Turbo133's Avatar
Turbo133 is on a distinguished road
im having the same problem some times its super fast clicking and sometimes it sounds like the blinker is just stuck on every ware i drive lol its pretty anoying
Old Jan 10, 2013 | 10:30 PM
iceflames11's Avatar
iceflames11 is on a distinguished road
I had this problem also. I replaced the turn signal relay, but that didn't work. I then replaced the multi switch (the one that controls the wipers/turn signals/ cruise control/ect) and that fixed the issue. While I was replacing it, I noticed the wire harness connection was damaged so that may have contributed to the problem. I also noted that the unit itself was rather worn and loose compared to the new one. It's worth checking out. YouTube has a great video on dismantling the steering column to replace it.
Old Jan 11, 2013 | 02:56 PM
okiedoak20's Avatar
yep same problem with mine, constant clicking like a turn signal..
i tryed the fix for the hazzerd lights, but that did not work, so i found a replacment turn signal assy. at RockAuto.com for cheap and installed it..
clicking is gone,and i have bright new white letters on the turn signal
stalk again, like factory new
Old Jan 11, 2013 | 08:25 PM
beehall's Avatar
The clicking is no where near as slow as a turn signal or a hazard. It is much, much faster. Kinda like a couple of bb's being shaken in a small jar. Not very loud, but very rapid.
After flushing out the heater core yesterday, I went to start it up. Nothing but the heavy clicks of a weak battery or starter issue. So, I checked the battery terminals. One was loose. Tightened that & is started normally. Seems that the rapid clicking has decreased. Is there any way that it could be related to low battery voltage??
TheNasty0ne
Dec 3, 2010 04:14 PM
xderkax
Jan 19, 2010 05:28 PM
Project_ZR2
Jun 16, 2009 10:03 PM
enigmattic
Jan 2, 2009 09:06 AM
apekim
Sep 15, 2007 10:46 AM
