disable auto head lights? questions
Old Jun 5, 2011 | 09:08 PM
zedartwo's Avatar
I'm with him!^^^^^
But as you wish:
No it is not the same.
I believe the DRL disable for your model is open the under hood fuse box and either pull the DRL fuse (NOT RELAY), Or pull the relay and bend pin #86 up (or cut but I do not recommend this unless you have another one lying around) and replace.
Search just in case because my memory has failed me before.
Old Jun 6, 2011 | 07:17 PM
tornado_735's Avatar
tornado_735 is on a distinguished road
I'm having the same issue where the DRL's and the DIM's are on at the same time on my '98.
I don't mind the DRL's but I am annoyed by the automatic headlamps.
I'm going to pull the DRL fuse (black one with a little arrow in the under hood fuse block) until I can do the resistor mod.
Old Jun 6, 2011 | 07:57 PM
96jimmyslt4x4's Avatar
96jimmyslt4x4 is on a distinguished road
I took out the fuse to the daytime running lights in my 96 jimmy.
I put the parking lights on when I want orange and what not.
Only put the headlights on completely when I want them on.
Old Jun 7, 2011 | 05:33 PM
Sturg's Avatar
Sturg is on a distinguished road
https://blazerforum.com/forum/tech-a...disable-54549/
Thats the auto headlight disable. To get rid of the daytime running lights you have to pull the relay out and bend a certain pin back...
search is your friend.
Old Jun 12, 2011 | 07:05 PM
drovemychevytothelevy's Avatar
drovemychevytothelevy is on a distinguished road
i wasnt saying i dont want lights on at night im saying im not a moron that needs the car to put them on for me lol i want to turn my lights on when i want them to be on and off when i want them off day or night ill find the fuse tho thanks for the info fuses didnt even cross my mind
and ive been apart of many other car fourms in the past if u didnt realize this thread is old which means i had to search to find it...
and thank you for the write up will probably do that tommorow
Last edited by swartlkk; Jun 12, 2011 at 07:12 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Jun 12, 2011 | 07:09 PM
An '01 is completely different than a '96... Read through the thread that Sturg posted just above yours. It covers things very well.
And please use the edit feature to add more info to your post in order to stay in compliance with the rules of the forum. You might also want to skip the insults/name-calling even if its just a broad statement...
Old Jun 12, 2011 | 07:16 PM
i did not insult anyone or call anyone names... i just cant stand the whole lets jump down every new guys throat kinda thing especially bc if they were paying attention i found this through searching just proving my point, not trying to start up problems wit neone
Old Jun 12, 2011 | 07:19 PM
You made a broad statement that anyone that uses automatic headlights is a moron. That kind of stuff has no place here, hence the subtle warning.
And I really don't see what you consider "jump down every new guy's throat". I guess it's all in your mood/state-of-mind at the time you read the statement.
Old Jun 12, 2011 | 07:47 PM
Daytime running lights go on when the car is on basically.
Pull the fuse and they never go on.
Then you can turn the parking lights or headlights on whenever you want.
Does that answer your question?
Old Jun 12, 2011 | 07:54 PM
those were not my words... but im not going to sit here and argue back and forth with u
