disable auto head lights? questions
I'm with him!^^^^^
But as you wish:
No it is not the same.
I believe the DRL disable for your model is open the under hood fuse box and either pull the DRL fuse (NOT RELAY), Or pull the relay and bend pin #86 up (or cut but I do not recommend this unless you have another one lying around) and replace.
Search just in case because my memory has failed me before.
But as you wish:
I'm having the same issue where the DRL's and the DIM's are on at the same time on my '98.
I don't mind the DRL's but I am annoyed by the automatic headlamps.
I'm going to pull the DRL fuse (black one with a little arrow in the under hood fuse block) until I can do the resistor mod.
https://blazerforum.com/forum/tech-a...disable-54549/
Thats the auto headlight disable. To get rid of the daytime running lights you have to pull the relay out and bend a certain pin back...
search is your friend.
i wasnt saying i dont want lights on at night im saying im not a moron that needs the car to put them on for me lol i want to turn my lights on when i want them to be on and off when i want them off day or night ill find the fuse tho thanks for the info fuses didnt even cross my mind
and ive been apart of many other car fourms in the past if u didnt realize this thread is old which means i had to search to find it...
and thank you for the write up will probably do that tommorow
Last edited by swartlkk; Jun 12, 2011 at 07:12 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
An '01 is completely different than a '96... Read through the thread that Sturg posted just above yours. It covers things very well.
And please use the edit feature to add more info to your post in order to stay in compliance with the rules of the forum.
You might also want to skip the insults/name-calling even if its just a broad statement...
i did not insult anyone or call anyone names... i just cant stand the whole lets jump down every new guys throat kinda thing especially bc if they were paying attention i found this through searching just proving my point, not trying to start up problems wit neone
You made a broad statement that anyone that uses automatic headlights is a moron. That kind of stuff has no place here, hence the subtle warning.
And I really don't see what you consider "jump down every new guy's throat". I guess it's all in your mood/state-of-mind at the time you read the statement.
