Disconnected harnesses, please help identify.
Old Jun 9, 2019 | 10:44 PM
James Gilbert's Avatar
James Gilbert is on a distinguished road
Default Disconnected harnesses, please help identify.
I have a 99 Chevy Blazer LS... I had to change out my combination switch (Turn signal, cruise control arm) due to the rear brake lights not working. While taking apart the dash I came across a myriad of wiring issues. It seems the previous owner figured himself a electrician.
Can anyone help me identify these wire harnesses that were located underneath the dash. Both are on the left side of the drivers foot room area.
Pictured are two harnesses. One black with four female connectors and one gray with a burn mark and one connector.
I've also included the dangerous wiring I found. The two cables wrapped together are for the cruise control. The white cable spliced into the harness is unknown. I simply cut it off and taped the end when replacing the combination switch.
Thank you in advance.
Old Jun 10, 2019 | 05:55 AM
Blazer112's Avatar
Blazer112 is on a distinguished road
Default Id
The gray plastic burned piece is a socket for your under-dash light bulb. I will trace the other when I get home.
Old Jun 10, 2019 | 06:23 AM
Blazer112's Avatar
By the way, my under-dash sockets (2) display that exact same charring. It’s normal do to
excessive heat from the bulb in a confined area. I replaced mine with an LED.
Old Jun 10, 2019 | 01:21 PM
Oh haha! That makes sense! Please let me know if you find the other one!
Old Jun 11, 2019 | 05:45 PM
Blazer112's Avatar
I did not find the other connector on my 04. Sorry, but I didn’t even find one similar and I checked extensively.
Old Jun 12, 2019 | 01:25 AM
Thank you very much for trying! I will do some investigating this weekend. Will post if I figure it out.
Old Jun 12, 2019 | 05:38 AM
Blazer112's Avatar
The one with the purple wires, did you find that after taking off your dash bezel/trim plate in the area of your headlight switch?
Old Jun 12, 2019 | 11:49 PM
The area I dismantled was located where the drivers legs go. One insulated piece was removed above the gas and brake pedal and one piece that is connected to the parking brake release.
N. Jensen
Nov 14, 2024 01:34 PM
killallblue
Jan 27, 2013 05:31 PM
Blazer_Man_Dan
Jan 3, 2013 08:35 PM
jimmyjam8586
Dec 9, 2012 08:09 PM
HcHawks09
Aug 10, 2011 10:49 AM
