Dome/courtesy lights work with dimmer switch, but not with door switches
Old May 12, 2022 | 11:55 AM
GeorgeLG's Avatar
"all that's left is the two new switches."
Or the associated wiring.
George
Old May 12, 2022 | 12:27 PM
jdjonesdr's Avatar
jdjonesdr is on a distinguished road
Roger that. I'm going to pull the switch, unplug the wires and check it with a test light.
If I've got power, it's the switch.
No power, I'll have to see why under the dash.
I know it's not the fuse because the dash dimmer switch is on the same fuse as the jamb switches, and it works.
I'm just waiting for the sun to drop a bit so it's not so dang hot outside.
I'll let ya'll know later.
Old May 12, 2022 | 12:40 PM
GeorgeLG's Avatar
Not necessarily, depends on where your going to ground your test light.. The reason why I suggested grounding both sides of the switch is because it can also be the wiring including the ground side from the switch to the frame.
If you get lights by grounding the upstream side of the switch then its either the switch or the ground wire from the switch to the frame
If you get no lights when you ground the upside side of the switch then its the wire from the upstream splice to the switch.
If you did get lights grounding the upstream side then ground the downstream side of the switch. If lights its the ground wire from the switch to the frame. If no lights then its the switch.
Another thing you can do is remove the switch and measure resistance as you engage it.
On trucks that are two decades old its the wiring a good percentage of the time.
George
Old May 12, 2022 | 01:51 PM
I hope you guys get it figured out. Glad I could do something to help.
Old May 12, 2022 | 03:12 PM
jdjonesdr's Avatar
OK, so I removed both switches and they're working properly. I also noticed the glove box light isn't lighting either.
There is no voltage to the connector, so I've got a disconnect somewhere between the switch and probably in the wiring under the steering column.
BTW, the positive wire is brown, not white as the schematic indicates. The black wire ground ohms out at well, so all good there.
Tomorrow I'll start looking at wiring around the steering column. I'd bet it's a connector that pulled loose when I was changing the dimmer switch.
I'll keep you informed.
Old May 12, 2022 | 03:43 PM
GeorgeLG's Avatar
Note that if corrosion, frayed wires, or a poor connection is involved a compromised circuit will not reveal itself unless it’s under its full load. Because of this open circuit voltages and ground resistance with no current flowing sometimes doesn’t find the problem.
George
Old May 12, 2022 | 03:45 PM
jdjonesdr's Avatar
Thanks, I'll keep that in mind.
Luckily I live in a warm climate and have a very clean truck that has been well taken care of, so corrosion so far has not been a problem. But I never say never!
03Blazers
Jan 17, 2019 11:21 PM
habafab
Dec 14, 2014 10:56 AM
mboggess
Jul 16, 2008 09:00 PM
myetman
Jul 27, 2006 02:18 PM
john65807
Feb 13, 2006 04:06 PM
