General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
interior lights wont go out
Old Feb 6, 2006 | 06:53 PM
john65807's Avatar
john65807 is an unknown quantity at this point
Default interior lights wont go out
for some reason my dome light and the lights in the rearview mirror will not go out. I suspect a bad door switch can anyone tell me if the mirror lights come one with the dome when the door is opened ????[:@] thank for your advice John
Old Feb 6, 2006 | 07:16 PM
Default RE: interior lights wont go out
If you don't have the dimmer all the way up, then it definitely sounds like a door switch. I believe that the doors work off of a switched ground (single wire) and actually complete the ground when the switch is out. You could pull the switches one at a time until the lights turn off. If by chance they work off of an interupted ground, then you'd have to ground the wire out of the switch to the chassis to check the switches.
Old Feb 6, 2006 | 07:26 PM
Hanr3's Avatar
Check your dimmer switch first. You wouldn't be the first person to trouble shoot dome lights on all the time. Took me almost an hour to figure out why the dome lights were staying on. Then I realized it had a switch on the rear dome light that we never saw before, however we must have flipped it while unloading the truck.
Old Feb 8, 2006 | 10:45 AM
matt_87_s10_blazer's Avatar
matt_87_s10_blazer is an unknown quantity at this point
im having the same problem on my 88 i checked the soor switches and the are fine i replaced the dimmer and still nothing
Old Feb 10, 2006 | 03:32 PM
gravix's Avatar
gravix is an unknown quantity at this point
On my blazer there "door open" pin switches on both doors, and also switches in the door handles. e.g., the lights come on if the doors are locked and you pull the inside or outside handles. Not sure why they did it this way at the factory, but it's convenient because you can wire up a warning chirp to the dome lights if you're adding an alarm system.
Anyway if you have the handle switches as well they could be culprits.
Old Feb 13, 2006 | 04:06 PM
Hanr3's Avatar
The lights activating with the door handles is a convience feature. The doom lights come on when you lift the handle so you can see inside your purse or find the right key on the key ring if your parked in a dark place at night. They took it a step further and put a conveince light in the outside mirrors.
cdp1250
Feb 6, 2010 01:11 PM
westleybidlock
May 24, 2009 02:29 PM
lt170chevelle
Nov 13, 2008 12:10 PM
jagblazer01
Oct 3, 2007 07:45 PM
Melodyjn
Jan 12, 2007 09:24 PM
