Dome light and locks
Old Aug 13, 2019 | 08:12 AM
Julie Martin's Avatar
Julie Martin is on a distinguished road
Default Dome light and locks
After having some welding done to the driver door hinge the dome light will not turn off...after getting home the.front door power locks are stuck in locked position and will not shut????
Old Aug 13, 2019 | 11:29 AM
Could there have been damage to the wiring harness that goes from the door to the body? Either physical damage or heat damage? There are likely electrical components inside the body behind where the hinge attaches to the body. I would think damage could occur there too. If you search threads on how to get a view of that area or threads that show the panels removed that would show what is there that may help.
Old Aug 13, 2019 | 11:32 AM
Also, about the power door locks. Are you saying that even if you manually unlock the door from the inside or from the outside with the key, the electrical door lock mechanism instantly relocks the door?
If it just a matter of the door lock being in the locked position with the door open, the fix is to use the outside door handle to try to open the door and then use a large screwdriver to pry up the latch at the outside end of the door. The pulling up on the handle with the pulling out is what opens the latch.
sdarnell2618
May 22, 2017 04:10 PM
Jake--Blazer
14
Nov 18, 2013 04:44 PM
joeroket
Jul 24, 2010 04:28 PM
xderkax
Feb 13, 2010 06:21 PM
98Chevy
Oct 24, 2007 02:02 PM
