dome light stay on
Old Mar 11, 2011 | 11:17 AM
LowLife's Avatar
LowLife is on a distinguished road
Question dome light stay on
my 96 blazer 4dr lt dome light does turn off. anyone ever have this problem if so what was it, i have checked high and low for what it could be, but i cant figure it out. i just take out the bulb so it doesnt kill my battery, but i would like to have a dome light. all i can think of is the things that are in the dash that push in when the door shuts are broken or just not working correct but i cant remember for the life of me what they are called i think they are door jamb switches but i just wanted to double check...what is confusing me is my bravada had the door jamb switches removed and i just tucked the wires up under the dash and my dome light turned on and off just fine
Old Mar 12, 2011 | 07:23 PM
LowLife's Avatar
well just a update i got the dome light to turn off, ended up being faulty door jamb switches
Old Mar 23, 2011 | 05:02 PM
LowLife's Avatar
well back to the dome light not turning off, today after i got into my truck the light wont turn off again. I had the new door jamb switches in for about a week give or take and everything was working just as it should, but now the only thing i can do to make the light turn off again is to pull the bulb or remove the #2 fuse from the driver side fuse panel....anyone out there got any suggestion as of what could of gone wrong now, thanks ahead of time for any input
Old Mar 23, 2011 | 06:00 PM
There has to still be a bad door switch and/or a short in the ground circuit that the door switches complete to turn the lights on.
Old Mar 24, 2011 | 03:03 AM
TNatus23's Avatar
TNatus23 is on a distinguished road
Yea I Had the Same Problem For a While but I Just Played with the Switch enough and not it Shuts Off .. . Really Sucked having to Actually Go Outside and Jump it in 20 below when I got so used to my Remote Start . .
Old Mar 24, 2011 | 09:31 AM
LowLife's Avatar
well thats something i guess i will have to look into again, thanks guys for puttin me on the right path. i just cant understand after a week how my napa door jamb switches could be bad again, but cant rule it out until i check it, hopefully thats all it is. i will keep u all updated as soon as i find out i will let you all know what the problem was.
97blazer8488
Nov 4, 2015 04:48 AM
dano440
May 11, 2012 06:57 PM
necropenetrator
Oct 26, 2009 09:55 AM
otter360
Aug 28, 2008 10:54 AM
bgillette78
Mar 7, 2007 06:12 PM
