door dinger?
Pretty much its my door dinger,my driver and passenger control lights and ashtray lights all stopped working at same time..I was changing stock bulbs to led`s and I put one in backwards..When I used a screw driver to loosen bulb to turn it around as led`s are polar it sparked and all the above has stopped working...Now Im stumped and fuming on this lol..
I normally test a fuse with a multimeter .. I take the fuse and put the probes on each side.. If the meter rings the fuse is good..
your basically making a closed circuit that makes the meter tell you that you have a good connection.
