E Brake light stays on
Old Jul 29, 2011 | 12:54 AM
2001BlazerX's Avatar
2001BlazerX is on a distinguished road
Default E Brake light stays on
OK so i was driving around today and happened to look down and saw my IP light is on. No matter what i do it will not turn off. Does anyone know how to get rid of it? Is it a problem?
Old Aug 1, 2011 | 04:38 PM
Frog's Avatar
Frog is on a distinguished road
IIRC, check your actual brake fluid level. Some models have a sensor in the brake fluid reservoir that will turn the light on the dash on, to let you know you are low on brake fluid.
If that is not it....check your wiring on the E-Brake switch...is your e-brake hand or foot operated? If it is foot operated take your foot and put under and kinda pull up on the e-brake pedal as you pull the release lever...it might not be coming up all the way.
Old Aug 3, 2011 | 11:34 AM
G.I. joe's Avatar
G.I. joe is on a distinguished road
This happened to me once. The light will automatically turn on when the brake fluid is low.
I have also heard it will turn on if there is another issue with your brakes.
With mine as soon as the fluid issue was fixed the light went off. Hope this helps!!!
armydad71
15
Dec 8, 2011 06:42 AM
Doggpool
May 24, 2011 08:17 PM
upmaine
Aug 28, 2010 07:56 PM
blazerscooby
Feb 10, 2006 09:09 PM
