Easiest tap into accessory power
Old Dec 1, 2016 | 02:42 PM
pizzalover's Avatar
pizzalover is on a distinguished road
Question Easiest tap into accessory power
Hey, 2005 Blazer 2 door here.
I need to run a remote power wire to my amp so that it's not always on. Where is the easiest place to tap into an accessory circuit? I just finished putting the dash back together and would prefer not to open it up again if there's an easier option.
Thanks!
Old Dec 1, 2016 | 03:12 PM
95teal4x4's Avatar
95teal4x4 is on a distinguished road
Well i ran the power wire from my led's to a fuse holder in my fuse block in the side of my dash. It was for one of the accessories i didn't have and i just plugged a terminal connector in the plug through a fuse and then to my switch and then from the switch to the front of the car. Mine is a 95, im assuming you have the fuse block in your dash. So they only have power when the car is in run or accessory. There ya go, if you need it i can post a pic of it.
Old Dec 1, 2016 | 03:22 PM
pizzalover's Avatar
Thanks for the suggestion. I do have a fuse box near the driver side door. How did you connect the wire to one of the unused fuse slots?
Old Dec 1, 2016 | 03:42 PM
95teal4x4's Avatar
Its been a couple months but i am almost positive i stuck a small length of solid copper wire into the power side of the fuse holder, then ran the other end of it to a section of stranded wire. i crimped the wire between them, only since it was inside the car and not exposed to the elements and then ran a connector to a regular fuse and then off to my switch. here is a pic
although i forgot that you may be using a high gauge wire, if so this might be a little difficult for you. What gauge wire are you using? Depending on if it is too big to do this, i think i know how you can use a relay to do it for bigger wire too.
Old Dec 1, 2016 | 03:52 PM
pizzalover's Avatar
That should work, thanks a lot. It's very thin wire just for remote power detection. The main amp power runs straight from the battery and has an inline fuse. Cheers!
Old Dec 1, 2016 | 03:55 PM
95teal4x4's Avatar
Ah ok great, Good Luck!
Old Dec 2, 2016 | 12:29 PM
pizzalover's Avatar
Thanks for your help! It worked perfectly. I found the easiest way to connect the wire to the fuse box with a sturdy connection was to insert the wire into the bottom of the specific fuse slot (on the side that would be protected by the fuse), and then insert the fuse so that it pushes the wire against the inside of the slot and creates a very snug fit.
I used fuse #9 if I remember correctly, which was for the HVAC system. When the car turns off, the power turns off on the amp. Perfect!
Now to hide some cables and we're done. The system sounds fantastic.
Cheers
Old Dec 3, 2016 | 10:25 AM
95teal4x4's Avatar
Great, I'm glad I could help and it worked for you
stinz
May 19, 2013 10:31 PM
drumminsoul
Jan 13, 2012 04:16 AM
litterbug
May 6, 2011 08:23 AM
global_dev
Nov 24, 2009 06:42 AM
zsipe41
Feb 6, 2007 01:03 AM
