Elec.Windows,Blower motor not working
Old Jun 11, 2012 | 04:48 PM
mattman's Avatar
mattman is on a distinguished road
Default Elec.Windows,Blower motor not working
I have a 1998 s10 blazer checked fuses and wiring just can't figure this one out. The power to these fuses is about 1/2 of what i get from all others. Any ideas out there its making me pull my hair out. Also when i push the switch for the window the ABS light flashes if that helps anyone.
Old Jun 12, 2012 | 12:50 PM
It really sounds like you have a grounding issue somewhere under the dash. Either that, or an issue with the ignition switch or possibly an issue with the 'IGN B' (50A MAXI) Fuse in the underhood fuse box which feeds both of the contacts that switch power to the circuits responsible for these two systems in the ignition switch. Attached are the schematics for the windows & the manual hvac system (assumed manual).
Attached Thumbnails Elec.Windows,Blower motor not working-1998_pwr_wdo_sch.gif   Elec.Windows,Blower motor not working-1998_man_ac_sch.gif
Old Jun 14, 2012 | 09:03 PM
mattman's Avatar
Been out of pocket, but this is what I did I changed out the ignition switch nothing changed. While doing that I checked the grounds all are good. Now for that IGN B fuse I can't find a fuse box under the hood on this blazer. If this helps its a S10
Old Jun 20, 2012 | 09:12 PM
cadaver666's Avatar
cadaver666 is an unknown quantity at this point
I need to replace my ignition switch on my 94, im having the same problems you are, windows not working, fan blows every so often, but I dont know how to replace the ignition switch, it seems 94 is the hardest year to get info on, if anyone can give me some tips, advise or a link to help me I would really appreciate it!!!
Jamie Blank
Oct 9, 2014 08:31 AM
Limey
May 7, 2014 10:19 AM
jrb_fishy
Dec 23, 2013 06:15 PM
bootlegger
Dec 14, 2010 05:18 PM
swact
Oct 5, 2010 02:55 PM
