Flashing headlights?
Is it just my blazer, or can you not flash your headlights? I've tested it before with my sister and nothing happens when I try to flash my headlights (lights turned off.)
Is something just broken?
If it has DRL's you should be able to.. if not, oh well. I've never seen a vehicle without DRL's have the ability to flash when they are off.
yea mine did that before I disabled them... can you flash them when your lights are on?
my drl is disabled and i can still flash the highs no problem.
I have DRL's & 1 1/2 pull back on the turn signal & my high beams flash. Not sure about during the day but I think they do.
DRL = Daytime Running Lights
Are you talking about Flash to Pass?
GM started doing that on the newer models. Our '95 Suburban doesn't have that either.
Basically the High Beams turn on before you pull the lever all the way back to switch them on.
when you're daytime runners are on you should be able to hit the high beam switch and the will stay on only for as long as you have the switch held back
Alright, I'll try these today and see if it works!
247monster
07-11-2012 08:41 PM
hollywoodgrad
01-25-2012 01:58 PM
247monster
01-24-2012 10:07 PM
blazerbenson
03-05-2011 08:24 PM
