Fuel gauge always reads E
Old Mar 28, 2018 | 02:41 PM
1997chevblazer's Avatar
1997chevblazer is on a distinguished road
Default Fuel gauge always reads E
Hello I have a 97 Chevy 2dr 4wd blazer, the fuel gauge always reads E when you turn the key off it floats back up to between E and half a tank but as soon as you Turn the key on it drops back to E. Anyone have any idea what to do? Thanks
Old Mar 28, 2018 | 03:10 PM
newguy's Avatar
Bad connection or the float may be messed up in the tank. I would look at the connections on top of the tank and look for the ground first. Ground may be dirty. Do this first before pulling the tank.
Old Mar 29, 2018 | 09:11 AM
Any idea where the ground would be??
Old Mar 29, 2018 | 03:47 PM
newguy's Avatar
Old Mar 29, 2018 | 04:48 PM
wokeupgrumpy's Avatar
wokeupgrumpy is on a distinguished road
Default Fuel gauge
Usually when the fuel gauge goes wonky, it is a problem with the fuel pump harness. It has to bereplaced. Very common GM issue. Sometimes coincides with an impending fuel pump failure. The contacts in connector housing get hot, form corrosion and things just go south from there
Old Mar 29, 2018 | 05:57 PM
newguy's Avatar
True, but I dont want him to buy a pump if its not needed. Dont just throw money at it till its fixed
Old Mar 29, 2018 | 06:49 PM
Default Agree
The replacement harness would be pretty cheap to try. I've had 3 Malibu's, 1 Grand Am, 1 Cavalier and 2 GM pickups thst followed the same path over sevseral years. A few weeks if not days after the gauge went wonky, the fuel pump died. My advice, try the harness first. Gonna have to drop the tank eithrr way.
Blessed23
Sep 27, 2014 06:50 AM
RMcwill@aol.com
Feb 7, 2013 11:08 AM
Olds Guy
Nov 11, 2010 09:21 PM
chipo022
Jun 1, 2009 03:12 PM
blazerguy22
Dec 12, 2008 07:59 PM
