fuel pump woes
fuel pump woes
97 blazer 4 door 4.3w. can anyone tell me exactly where the fuel pump harness grounds to. fp problems i think possible bad ground. thanks
I could tell you on the 2 door but that doesn't help you at all. Sorry.
It grounds to the rear frame on my 94. Pretty easy to check that out.
On the 2 door, the ground is at the same place that the anti-static/ground strap grounds to. Look around in the immediate area for a loose black wire that should have a round connector, that'll be your ground.
They changed the wire harness on the fuel pump. When you buy a new one it comes with a new style connector that you have to wire into the old haeness. That is why mine went out.
BouncingRadical
14
11-27-2015 12:30 AM
cide
11-07-2009 01:26 PM
mytruck2
12-13-2006 04:50 PM
