gauges not working
Old Sep 16, 2014 | 07:16 PM
sacnfox85's Avatar
sacnfox85 is on a distinguished road
Default gauges not working
Soo heres my dilema my gauges come on every now and then on my 01 blazer start it up all the gauges and lights work but after running for alil bit they all turn off i changed the ignition switch and it didnt seem to help at all i let it sit for awhile and it goes back to normal im at a loss
Old Sep 16, 2014 | 08:18 PM
richphotos's Avatar
You could check the ground, I believe there is a ground strap for the gauges under the drivers side dash above the e-brake pedal. I know there is one on first gens, not 100% on second gens, worth a look.
Old Sep 17, 2014 | 07:34 AM
sacnfox85's Avatar
ok will give that a try id post a video of what its doing but im new to the forum it does have an aftermarket alarm system idk if thats whats doing it to it either
Old Oct 6, 2014 | 05:07 PM
grayman63's Avatar
grayman63 is on a distinguished road
I was having a similar problem, mine was a wire that rusted off under the fuse panel in the engine compartment. Took a while to find it. So I'm happy to share.
Old Oct 6, 2014 | 09:15 PM
sacnfox85's Avatar
Thanks grayman63 now all my gauges dont work jus the "CEL" and it wont start at all checked all grounds cleaned them all up and still no start if i have the key in the run position and manually squeeze the starter relay it starts up but i will check the wires under the fuse block in the engine compartment hopefully ill fimd something there was gonna post a new thread but decided not too hopefully people are chimming in and give there two cents on this....
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
crawford22
May 3, 2011 10:54 PM
frostblazer
Jun 15, 2010 10:25 PM
azari215
Feb 12, 2009 09:31 PM
weston
Nov 28, 2006 12:28 PM
