hazard he##
Sounds like a bad flasher unit. I'm safe to assume the clicking sound stops as well?
If so I would target the flasher unit which I believe in the 98's is located behind the glove box.
Remove the contents of your glove box before pressing on the retention pin in the left top corner to allow the box to swing down into the footwell allowing for access behind it. Flasher unit will be a small little relay box on the right side with a white or green retention strap around the outside of it.
I can't remove the glove box because the vehicle is modified to drive on the right hand side is there another way to get to it??
