Head display temperature wrong
Old Sep 16, 2012 | 12:37 PM
Marcin's Avatar
Marcin is an unknown quantity at this point
Default Head display temperature wrong
Hi
My head display temperature is showed much too high. For example today was cloudy cold day and temperature was shown above 100F. I changed outside air temperature sensor but temperature still is to high. Where the problem is located? Any ideas?
Marcin
Old Sep 16, 2012 | 01:11 PM
Rottidog's Avatar
The sensor should be under the hood latch on the grille. Mine always reads a few degrees off but not THAT much.
Check the wiring to it etc. There have been posts about them in here so maybe a search will help.
Old Sep 16, 2012 | 02:17 PM
Marcin's Avatar
Hi
I have replaced sensor today. And the problem still exist. Maybe problem with ground connection? But where to check?
Old Sep 16, 2012 | 02:30 PM
Rottidog's Avatar
Follow the wires. If there's only 1 then it uses the metal hood catch frame as a ground. Scuff it up & see if that helps.
Old Sep 19, 2012 | 12:24 AM
kody070's Avatar
kody070 is on a distinguished road
I have same problem it always says it's like 46 when it's really like 80 or when it's 50 it says warning ice and 32. Never made sense to me. What does the sensor look like? I'm sure it's fine so what's the deal with these things.
Old Sep 19, 2012 | 12:31 AM
Rottidog's Avatar
As far as I remember (being inside, 12:30 AM) it's a little black 'nipple' looking thing mounted where I said earlier.
Might be grey or whatever... it'll be the only thing mounted to the hood latch column behind the grille with 2 wires.
Look under the catch for the hood & behind.
Old Sep 24, 2012 | 04:14 AM
Marcin's Avatar
Hi. I have checked wires and I have good ground connection. Voltage is little bit more than 5V on sensor connection. So my conclusion is that overhead console (OHC) is wrong. Now I will try to check resistors and electrolytic capacitors on OHC PCB.
blazerxtreem
Jul 12, 2013 08:06 PM
BB3439
Dec 12, 2012 01:57 AM
haloboy99
Sep 18, 2011 08:43 PM
J.R. Clay
Mar 17, 2011 08:22 PM
KyFritz02Xtrm
Sep 26, 2009 12:48 PM
