Head lamp switch powering on fuel pump,ignition,interior lights ect
Old Jan 29, 2017 | 07:42 PM
Jakebiker222's Avatar
Jakebiker222 is on a distinguished road
Default Head lamp switch powering on fuel pump,ignition,interior lights ect
I have a 98 blazer thats having some issues.if i turn my head lamp switch on with key off it powers on fuel pump.ignition and half my dash cluster.the head lamps them selves arnt powering on.no power being sent to head lamp plug at bulb.if i turn the head lamp switch on with the rig running it kills the rig.i have checked and cleaned every ground and positive conection.ive replaced every relay under the hood including the ones under the dash on the drivers side.i chacked power and pins for all relays and everything correct.from what ive read the bcm could of gone bad.has anyone has similar problems
Old Jan 30, 2017 | 06:12 PM
rockp2's Avatar
I'd be more inclined to think that you have an ignition switch problem. Common in these trucks.
Thrash4u
Dec 18, 2015 05:33 PM
DBULL
Mar 15, 2014 12:47 AM
Jrbruno4208
Aug 23, 2011 06:01 PM
pwtrash25
May 31, 2011 03:14 PM
