97 Jimmy interior& dash lamp problems
Old Jan 2, 2014 | 03:50 PM
DBULL's Avatar
DBULL is on a distinguished road
Default 97 Jimmy interior& dash lamp problems
My 97 Jimmy's interior lamps weren't working when I purchased it.Upon initial inspection,I discovered that fuse 2 (courtesy) was missing.I installed a 20a fuse and now have lights but they won't turn off.My dash illumination lamps are also not working,but I believe they are on a different circuit.All gauges work and the brightness control changes the output of the radio/heater illumination lamps.All park/headlamp/flashers work as they should.Any input would be much appreciated.Thanks,DBULL
Old Jan 13, 2014 | 05:48 PM
DBULL's Avatar
Figured it out! Thanks.
Old Feb 22, 2014 | 08:32 PM
Grandpaswagon's Avatar
Grandpaswagon is on a distinguished road
What was the problem? I am having the exact same issue with my '97 Blazer (interior lights won't turn off).
Old Feb 22, 2014 | 09:32 PM
tery's Avatar
tery is on a distinguished road
I cannot figure out why I have no overhead lights when the door is opened, Everything else seems to work but funny>?? that clock and overhead computer lights don't turn on unless you turn on the headlights.. Any ideas where to look next??
Old Feb 22, 2014 | 10:49 PM
Bildo V.'s Avatar
Bildo V. is on a distinguished road
I actually went through a situation very similar to this I found the solution through some research and by accident. what happens on these is that there are wires under the under hood fuse block that like to corrode and break causing this issue to occur. so i'd start by CAREFULLY loosening and inspecting the wires under the fuse block located in the engine bay
Old Feb 23, 2014 | 03:35 PM
To the best of my knowledge, there is no underhood fuse block on a '97 Chevy Blazer.
Old Mar 13, 2014 | 09:52 PM
Bildo V.'s Avatar
I believe you to be correct sir, I was just throwing in my experience as my problem plagued me for almost 3 yrs. tery didn't provide and vehicle details so I threw that out there
Old Mar 14, 2014 | 08:52 AM
Chic_Bowdrie's Avatar
Chic_Bowdrie is on a distinguished road
The problem may have been the door latch sensor. If working properly, it will turn on the dome light when you pull up the door handle even when the door is still closed. If the sensor is defective, it will keep the dome light on and run the battery down. That's why DBULL's fuse was missing.
Old Mar 14, 2014 | 09:01 AM
berniescout's Avatar
berniescout is an unknown quantity at this point
97 blazer indoor lights not shutting off. switch not making contact to door panel. switch is in the side of the dash and contacts the raised boss on plastic door panel. real problem was bad door hinge allowing door to not close properly. temp solution duct tape a quater on dimple to depress switch. real solution replace worn door hinge pin .
bernie
Old Mar 15, 2014 | 12:47 AM
I figured mine out and it was a door switch also. But not the front doors. It was the rear door on the driver side. The switch wasn't working, but I gave it a shot of electric contact cleaner and worked it in and out a few times and it is working now.
So make sure that you check all of the door switches and don't forget the rear hatch.
Chevy33
Dec 1, 2011 07:02 PM
jaxgent
Mar 8, 2011 09:26 PM
NCStone
Apr 4, 2007 03:31 PM
Loud_01_Blazer
Sep 13, 2006 07:21 PM
greengoose89
May 18, 2006 02:01 AM
